chupacabra
How do I clean the perforated in the leather that has old build up conditioner clog the holes? Toothpick is last resort.
Try a soft bristle brush. Even a toothbrush can work. I find it helpful to have a variety of small brushes of varying firmness on hand. "Tougher" brushes for scrubbing tires, engines,carpets, seats etc. as well as softer, longer bristles and longer handle brushes for delicate work like cleaning vents, I keep the brushes separated so I don't use the tire or engine brush on the carpet or seats.
You can even get rubber bristle brushes. These are good for pet hair. (Not magically efficient, but they work.) Also, rubber brushes are fairly easy to clean after use.
and if you are using Natural Look, if you rub really well with a coarse cotton cloth on application, it will clean the residue from past products
