A
aalves
Thin is the answer. Apply thin coats.
Did you use a DA?
No. By hand.
Hey Aalves
Process should be as follows for applying Black Hole topped with Ex-P
Apply the black hole by hand or machine. It does not have a "cure" time per say but you should wait till it flashes (pretty quick process). This will leave a light haze on the paints finish.
After the BH has flashed you will need to take a new clean microfiber towel and buff off the residue left behind (I think this is the part you are skipping)
You can than apply the EX-P it will need about 30 mins to haze over buff it off than keep it dry for 24hours so it can cure.
-Chris
I did exactly what you describe Pockets.
