From what I can tell, they're pretty much the same, results-wise, just different application methods. (Obviously you wouldn't dilute the gel, so if you like diluting BnB spray, you may need to experiment a bit with application of the gel to get the same look. I'd recommend either rubbing it in to stretch out the amount applied or wiping off "excess.")
