A
ajc347
Just wanted to check whether applying Pro Polish with a finishing pad would be sufficient to remove previous layers of wax / sealants or whether a polishing pad is needed?
BigLeegr said:It should be enough, as long as you don't go too fast.
BigLeegr said:Sorry, by "fast" I was referring to the speed of the passes, not the speed of the machine.
Redwings97 said:I would actually use speed 3.. Keep the speed down allows the product to work longer, giving it more cleaning time.
