So I'm planning to use PwS for the first time tomorrow. I will be using it with a white pad as I'd like to remove some scratches and swirls also. Is the cure time the same for PwS as it is for EX-P? As in, do I apply and let it sit for an hour before removing and then make sure it doesn't get wet for at least 12 hours?
Edit: Also, is it ok for use on plastics and glass?
