Order of application?
Snowdrift
Hello, I am a new member and I see my type of question is quite common. I would appreciate your feed back on the following: I have the following Poor Boy's product and was wondering if I have the order of application right? 1. (depending on condition of paint) either SSR1 or SSR2.5, 2. Professional polish 3. Polish with sealant, 4. sealant with canuba 5. either white diamond or black hole, (I have both a white car and a darker grey) 6. Natty's red. I thank you!
Yes, that's pretty much the order. You may not need to use PP if you use SSR1. Some people use both, some are good with just 1 or the other.
Same with using PwS. You may not need it in there. (You still can use it if you want, but in case time constraints are in effect, you could skip it)
Good luck!
