Some Help with Poorboys Products
K
kastanaras
Hello
Well Poorboys has many products and I am very confused what is what product.
Ok I know what all the dressings are, ssr line, and nattys paste waxes but confused with everything else such as sealants, polishes, qd, and everything else.
I am just confused what is what cos they all seem similar but can't tell difference and wondering if someone can sort of put them into categories so I can understand what is what.
it would probably be easiest if you wander through our product forums and ask questions under any catagory you have a question :D
K
kastanaras
Well these are the products I am confused about.
(Are these aio products and whats the difference between the 3)
Poorboys Pro-Polish
Poorboys Pro-Polish with Carnauba BLUE
Poorboys Polish with Sealant
(What is difference between these two)
Poorboys EX Sealant
Poorboys EX-P+
(And can you explain in short these products and which one does what)
Poorboys QW+
Poorboys Spray & Gloss
Poorboys World Spray and Wipe
I would write in other areas for these but would take forever to write up all of them just to find out difference between these products.
PP is just a polish, not an AIO. PwC (Polish with Carnauba) is an AIO. It is a light cleaner polish as well as some protection. PwC Blue is like PwC but formulated to work especially well on dark colors. PwS is a polish and sealant that is capable of doing some paint correction (remove cobwebbing and such).
EX is a pure sealant (not a polish) that has some carnauba in it to give it a "warmer look" such as one might expect with carnauba waxes, but should last like a sealant.
EX-P is also a pure sealant, but without any carnauba, so you get a "brighter" look. More typical of a sealant.
QW+ is a spray wax with some cleaning abilities. Can be used to remove light oxidation. Typically used as a booster between detailings. Lasts a fairly long time.
S+G is a gloss booster that can be used on either wet or dry cars. Not much for cleaning dust/dirt off cars, and doesn't boost protection. Used to bring back some pop such as before a show.
S+W is a "spray and wipe" type wash product. It doesn't add protection/gloss. Used to clean cars between bucket washes, such as before a show, after a bird bomb hit, dust settling on the car while you were at work. Stuff like that.
