QD+ Application method
ShawnF350
Well..Poorboy told me what I was doing wrong with applying QD+ and I figure I would share it with you. I always had to go back and rewipe many areas on my Dark Blue Ford Edge.
He suggests using a mist bottle. (8oz spray bottles sold in the PB store)
I gave a light mist to each panel while drying. To my amazement...No streaking.
Bunky
Yes, a misting spray is good. If you use the same towel as you wipe and buff, over time it will build up so you need to spray less. If you spray using a regular sprayer, try spraying while in a sweeping motion. The other approach is to use 2 towels - spread and buff. I find letting them "age" a few seconds after spreading it can help removal.
johnnyb
Good ideas in here, I'm always trying to improve my methods.
Sometimes I use the 2 towel method, sometimes a single towel. Sometimes I mist the wipe towel, instead of the vehicle (for those direct sun FL days I find it makes it easier to buff off).
