I used 2.5 on my black dodge then i applied nats blue and it has left a haze on the finish. Should I start with 2.5 then 1 or should I start with 2.5 then a polish....will the haze go away?
First tell us what pad you used with the SSR2.5 and at what speed did you apply it...
Possible problems are that you :
-Used too abrasive of a pad
-Didn't work it long enough for it to fully breakdown the SSR2.5
-Used the SSR2.5 at too slow a speed, again did not fully breakdown.
A little more information on your process will allow us to help more
Did the haze show up after applying the Natty's? Could be just uneven application, if so. Re-applying the Natty's may help even it out. Sometimes just some QD can help.
But if it's from the SSR2.5, then it won't be such an easy fix.
