mark9661
Black Sapphire Metallic (probably)
That should work. You might want to add sunglasses (you'll need em)
HaHa, hope so, thanks for the reply...
Just to add to this, I think I've hazed the paintwork in certain spots with Zano swirl remover. Any suggestions to correct this would be welcome.
It was vastly improved just by putting a coat of Black Hole over it, but I think it could be further improved with a different recipe.
What would you suggest ronkh?
try some sealant between the blackhole and wax.
there's nothing to say you can't do red and blue over one another, i do it regularly
Ive still got some Zaino Z2 sealant to use. It was quite expensive, would this be OK? Also, does the wax need to cure or can I use the sealant immediately?
