Combining PWS and SSR
I've been in the mood to try a new AIO and from the review I have read PWS is a chemical cleaner right? Would it be possible to add a drop or two of SSR1 with PWS on a white LC pad for a little more cut. thoughts?
How much did you add? I was thinking 3 drops PWS and 2 drops of a MC. Since PWS and PP@ are both chemical polishes I think I would be inclined to use master cut.
sorry, you have to be your own chemist .. every case will be different :D
so basically try a little and adjust from there. Well atleast you gave me a reason to try master cut. How much durability do you expect from PWS?
heck
Can I ask why?
PB has a complete line of products with built in progressive steps by changing product or pads.
I suggest try a PP2 with a green pad and let me know what you think.
mainly becuase I wanted an AIO with cut and not just a chemical cleaner and (please correct me if I am wrong) but PP2 and PWS have no cut. I understand that I can get cut from changing the aggressiveness of the pad but I am making an assumption that using a lighter pad with a diminishing abrasive will finish out better than a more aggressive pad with a chemical based cleaner.
I am by no means andy thing more than a weekend warrior and normally I don't even bother with AIOs since I baby my cars but I have a few friends who I am going to help out who have fairly neglected vechilces. Unfortunately they are not as passionate as I am about car care so I woln't be able to spend more than a few hours on each car.
awd330
Bumping an older thread here...
Did you ever get around to trying the SSR1 plus PwS mixture? I'd be interested in hearing about your results.
