Another PWS question
craig
Hi guys. I've been using on my last couple of details & i really cant praise it enough :)
Yesterday i used it on a heavily oxadized golf gti & because the paint was so hard i switched from a regular polishing pad (white hexlogic) to a heavy polishing pad (green hexlogic) & turned my polisher speed up a little more. It performed really well & removed a suprising amount of defects, but i did wonder if i have compramised the effect of the sealant going in hard & fast !!!
Should i of topped the pws with another lsp, or am i worrying too much lol
Craig :)
Hey Craig,
Yes, Polish w/ Sealant is a pad dependent product and can remove quit a bit when paired with a cutting pad. But as you worried it will surly diminish the effectiveness of the sealant as the heat generated and abrasiveness of the cutting pad will do that.
I would top it with a designated protection step after doing something like that. You could also do another pass of the PWS on just a finishing pad and that will leave a layer of protection as well
