Whats the Performance of ya motors....
Z
Zmaster2k
Thought this would be interesting to find out... as i know im not going to be the best at all!
Whats the Power of your car?
Bhp Per tonne?
Whats your best 1/4mile time?
Proven results only......
Bhp is 180bhp 146lbs/ft torque (graph available)
Bhp Per Tonne is:- 203.21per tonne
Best 1/4 time so far is a 14.50@96mph
(did that with mechanical sympathy no burn outs or 7k launches lol)
My car is built for track action not straight line drag so was quite happy with that)
So what you lot got?
W
wallywax
Here goes.
Weight= 3150lbs
Power= 415 hp, 390 tg to the wheels at 8lbs.
2003 Mustang gt 5spd. Bone stock 13.9 @ 99mph with bfg radials.
With vortech supercharger @ 8lbs of boost, 11.80 at 118 MPH with a 1.7 60ft time. I cannot wait to beef up the internals and crank the boost up to 14lbs :) should run 10's! Gotta love v8's!
zmaster2k those are good times with such little ponies :)!!!!
Z
Zmaster2k
Thanks muchly!...4 Cyl N/A power :D i love it... revy little thing.. should crack 13's with throttle bodies and 12's with forced induction.....but i want bodies... better for a track car!
mmmV8 power!
W
wallywax
Show us some more pics of that bad boy :)! Yah 4 cyl love to rev. Lots of fun!
Bunky
Where is the forum hosted? The system clock says it is 5/13 and 12:45am ....It is still 5/12 and 8:45pm eastern
I think pictures should be a must if you are going to post!
Gus-Gus
the time setting is set by you in your profile.. you need to set it to gmt -4
Z
Zmaster2k
hohkay!
Spec is here :
Engine
F7R 700 2.0-litre 16-valve
Kent RN2002 260 cams
Piper Vernier pulleys
Mocal 13 row Oil Cooler
Mocal Thermostatic sandwich plate
K-Tec Racing Low Temperature Thermostat
K-Tec Racing Low Temperature Fan Switch
Custom Oil lines from a tractor
Custom Live Remap by Kj16v
Full set of Orange Samco Hoses
Samco Vacuum Hosing in Orange
Re wrapped loom in “orange/peach”
Scuttle Group A Induction with Carbon intake
Williams Manifold
Sportex Straight though exhaust
Straight-through de-cat
Magnex Rear Silencer
Braided fuel lines
Group A 4th gearbox/subframe mount
F0xy 5th Subframe Mount
Rotated Standard new Dogbone mount
Highly Polished “Rocker” cover
Highly Polished Inlet Manifold
Highly Polished Fuel Rail
Highly polished Lifting eye
Powder coated Top Mount in Antique Silver
Powder coated Cam cover in Antique Silver
Powder coated Vacuum Lines in Antique Silver
Powder coated Slam Panel in Antique Silver
Powder coated Battery Tray in Antique Silver
Powder coated Gear box mount and strap in Antique Silver
Powder coated Alternator brackets in Antique Silver
Transmission
Jc5 Rebuilt Custom Gearbox (basically a mish mash of 4 different boxes)
Saches Clutch
New Genuine Renault Clutch cable
K-Tec Racing Short Shifter
Bolt In Diff Conversion
Brakes
Green Stuff Pads
Suspension
Williams Shocks
Unknown springs -55mm
Rear Torsion bar adjusted 2 clicks and Bias valve adjusted
Williams wide-track conversion
Powerflex Poly Bushes all round
Manual Steering
Wheels & Tyres
Williams Speedline 7x15-inch wheels (road)
Powdercoated in “sita bin” grey with orange Rim tape
195/50/15 Yokohama Parada Spec 2
Body
Renault 432 Monaco Blue
Smoothed Bonnet
Smoothed tailgate
Fog lights removed
Colour-coded and
Interior
Stripped entirely in the rear
Standerd Phase 2 Seats for now
Carbon fibre Door cards
Performance
186.1bhp @ 6600rpm @ fly
Performance (before 2.0 f7r fitment)
117.6bhp @ 6800rpm @ fly
Pics:)
pgcobravert
97 Mustang Cobra Convertible
stock hp rated at 305hp
3,565 lbs
not much done to it, just cold air, and 4.10 gears.
W
wallywax
With 4.10 gears and sticky tires a 97 Cobra should hit high 12's low 13's.
pgcobravert
I am not into drag racing much, I do love to take it out on the road courses when I get a chance. And, any time we hit the mountains in NC, love going through the twisties.
kitzy
I think he meant his vehicle is slow but he'll eventually get where he's going albeit somewhat later than some of the others.
CupraBrad
Currently running a standard Seat leon Cupra k1
240bhp as standard This will be increasing to around 300bhp in the next few months after my remap. and then up to 380bhp in a few years time!
Not run this on a 1/4 but people have said standard it will do a 1/4 is around 14seconds i believe
