what can i use for headlight that has turned yellow? can i use the ssr?
H hotgrass Guest Apr 10, 2008 #1 what can i use for headlight that has turned yellow? can i use the ssr?
BigLeegr Token Brute and Chief Bottle Washer Staff member Apr 11, 2008 #2 I'd try Pro Polish first. If you are doing it by hand, try using a cotton cloth, as it has a bit more bit than a foam applicator pad would.
