csvtjohnga
Going to be detailing a few cars in a month or so with PB products and would like a few tips and observations. 03 Ford Lightning in Sonic blue and a 04 Cobra in Screamin' Yellow. I'm familiar with Natty's Blue paste wax and will be using it as my topper. I purchased SSR1, Pro-Polish, Black Hole, and EX-P. I do not have access to a PC or any other type of machine for application/removal so all work will be done by hand.
SSR1-Pointless without a machine application? Not all of the body panels need it on either vehicle but would hand application work?
Black Hole- Cure time is 12-24hrs? Will be layering this and while it cures ill tend to other parts of the cars so time isn't a bother also vehicles will be garaged during full detail.
EX-P- Can be layered aswell and same cure time as Black Hole?
I understand to not let any of the products dry but to haze over and test by the finger swipe. Temps will be around 70-90 with 70+ humidty which I hope won't factor in too much. With the Yellow Cobra should Black Hole be applied? White Diamond would be the optimal glaze I'm guessing but would the BH help any? Both will get a good Claying to remove the surface contaminets. Before putting product on the pads should i give the pad a quick mist of QD+? I read that some do that but not sure why... Using PB Trim Restore on the trim and other exterior parts, seems like a easy application. I plan on using the line up first on the Contour(Toreador Red) just to get a good handle on how the products will work and how much product to use etc... Thanks for any input! I'll be sure to post before,during and after pictures too!
