Professional Polish
gotgone
I just finished doing a Ferrari Spyder using PP by hand. I applied it using a polishing pal. The finish looked great. I am wanting to use this product with my pc to do my Tundra. I know it is pad dependent. I thought I would start with a a gray pad and apply 3 or 4 pea sized drops. Is this the proper amount to apply to a pad? Same process with white pad just to see if it makes a difference. Can anyone tell me what speed to spread and work it at? I have been using SSR1.0 but thought I would try PP as it should be less aggressive. Thanks for any help.
You can spread it at a speed of 1-2 and then work it at 5-6 until it virtually disappears. You can work it longer than you expect, just stop the machine every once in a while to see if the pad is still slightly damp with product.
When it starts to dry up, add more product.
