Steve thanks for the reply. I actually had some spot on my car yesterday. A large majority was on the hood which is covered in 3M Venture Shield. I stated testing products to remove them. They were very stubborn and getting them off paint was much easier than the film. I am happy to report to you and the forum that I was able to clean them up with pro polish. I started by hand but after an hour of work and only completing a small section I moved to a DA. I used a GG DA with a Uber Green polishing pad at speed 4. I used about 10 pounds of pressure and worked the product in small sections. I worked it until the spots were gone and continued until the polish was just a slight haze on paint. Buffed of with a pb dmt and perfection. It was so easy and. Added so much gloss I did the whole car.
Wiped the car down with DI water and added 2 coats of black fire wet diamonds sealant.
