Poorboys ProPolish and Polish w/ Carnauba (or Polish w/ Sealant)
_Impulse
Hello all.
Just started using Poorboy's products - great stuff. They smell great, and are extremely easy to apply with my PC7424XP.
I'm interested in purchasing some products from the Pro Polish/PwC/PwS line.
Now I surmise that PwC/PwS is basically ProPolish, with some Carnauba/Sealant mixed in.
Does PwC therefore behave in the same way as ProPolish i.e.
- it has "actual" cut which is "pad dependant"?
- it can be used to remedy light swirls, without masking? (PwC, not PwC blue).
BTW, I should mention I intend to use ProPolish (or PwC/PwS) with either a white LC or black LC pad.
Thanks!
Pretty much
Just remember the more aggressive you "polish" and more aggressive pad, the less protection you leave behind with the pws/pwc
_Impulse
Interesting, had no idea the pad would influence the protection left behind. So I could technically use a white pad with PwC/PwS, and then follow again with a faster pass with a black pad (again with the same PwS/PwC) as a "finishing/protecting" step?
Then don't PwC/PwS render Pro Polish kinda redundant then?
no. What if you want to use a different lsp?
No they have different cleaning abilities and totally different chemicals ;)
