Polish Help
Bijibo23
The last time I detailed my car I wasn't getting the results I wanted using PwS applied with a PC/green edge 2k pad. I still see fine swirl marks and scratches. Should I try PP, PP2, or SSR1? I'm looking to follow it up with PwS then Natty's Blue. Appreciate the help :D
Yes, I would go with the SSR's. PwS is an All-In-One product, so it does fix a little marring, but not as well as a dedicated polish/SSR.
I don't think SSR1 will be enough. Try SSR2 or even 2.5 instead. I haven't tried PP2, so I can't comment on that option.
Bijibo23
Would the "new and improved" SSR2 be better than SSR2.5? I don't want any marring issues. Ideally I'd like to do one application of polish, then one of PwS, then Natty's Blue.
that would really depend on how bad the swirls are
Bijibo23
They're not terrible. I just don't think the chemical polished were cutting it. How much cure time between products?
there is no cure time with those products
W
wallywax
Take your time. Do small sections at a time. Also it is a good idea to do a small test area to see which product has enough bite for the imperfection.
gragento
I am think to apply Polish with Seleant to clean, white diamond and EX-P sealant. This setup is correct?
Merlin
Take Pride in your Ride!
I have always obtained real good results with SSR 2.5 and SSR 2 for removing swirls and fine scratches.
I might suggest SSR2 first (always use the least aggressive method first)
If that's not enough cut then go with the SSR 2.5 Do a test spot first.
When using these IMHO
Follow SSR 2.5 with SSR2
Follow SSR 2 with SSR1
