		Metro1288
Hi Guys,
I am new to the forum (car detailing as well) and am hoping to get some good info to help me with a major detail i am planning to do very soon.
The new car is only a couple months old and the paint (metallic black) is pretty good apart from tiny swirls i can see from close up when parked in the sun or under bright lighting. I will be doing all my work by hand so i have accepted that most of the polishing that i will be doing will be just masking the swirls and not removing them. I probably wash the car every 2 or 3 weeks and would be kind of on the lazier side.
The products i will be using:
Megiuars NXT Tech wash (already had this)
Claymagic Claybar (blue)
PB's Pro-polish with carn (blue)
PB's EX sealant
PB's Nattys Paste Wax Blue
Grey Ultra Soft towels
Waffle weave drying towel
Wolfgang wax and polish applicator
Megiuars round foam applicators (already had these)
Megiuars sheepskin mit (already had also)
I was thining about doing the following steps, would appreciate any info as to wether i am doing it correctly or not:
- Wash and dry with two bucket method and waffle weave
- clay using shampoo mix as the lubricant (what ratio should i be mixing? should i wash after this step?))
- Polish using the Wolfgang wax and polish applicator and the pro polish (this is the setp i am most unsure about as to how i should be applying. how much? how hard, any point in going twice over? etc)
- Apply EX (how many layers needed? do i need to wait at least 12 hours if i want to layer this?)
-Apply wax (any tips for easy application of this? its a bit cold here right now. can i layer immeadiately or do i need to wait?)
I have some other questions as well but i will put then into a separate post i think, this one is getting a bit too long. I really appreciate any tips you could give me as i want to try to get it right. I have a few mates waiting to see how my car turns out before they decide to get some products as well. Hoping to wow them with my results to get them into the hobby.
Cheers,
Metro
PB's EX sealant
Cheers,
Metro
