Need Help in Choosing Products
A
Atrocity
I need help in deciding what products are best for me. My car is white and has tiny black spots over it. So I would need to clay my car with Poorboy’s Elastic Clay and Poorboy’s Spray and Wipe. Now I don’t have an orbital buffer or Porter Cable buffer to finish the job. Which Poorboy’s products should be used next after claying the car? Could I just hand apply the products after claying? Should I invest in a Porter Cable for best results? I want to try and stick to one brand like Poorboy's so I can order from the site or distributor all at once.
If you can afford it, I would say go for the PC. Much better results are possible from it than a 'mart buffer and easier on the arms than doing more than minor correction by hand.
For the quickest, you could go with PwC or PwS after claying and be done.
If you wanted to do more than a one step, I will just say 'look around the site and see what strikes your fancy.' There are lots of combos depending an what a person is willing/able to do and what they are trying to accomplish.
A
Atrocity
Now I need to find a good deal on a Porter Cable. I know autogeek.net carries bundles. Is there anywhere I can find a great deal on a Porter Cable?
they can be found at Home Depot or Lowes, but then you will still need to order a backing plate and pads .. :smt102
Redwings97
Autogeek and Detail City are great companies to buy accessories from. I got my PC from Detail City (for Xmas) and have made purchases from both companies for pads, backing plates etc. I found that looking for the PC was about the same price from both companies, just the package I got had certain pads that I wanted to try. Also - get the 5" backing plate to use with both the 5" and 6.5" pads.
