Just a little help needed
mark25
Please can someone help me understand a few things about Poorboy's that I have been dying to find out and have not known who to ask until now ?
Whats the difference between Liquid Natty's Wax and QW+ and is their any advantages or disadvantages between the two products ?
Same question between Liquid Natty's Wax and Natty's Paste Wax ?
Whats the best way to use the Spray And Rinse Wheel Cleaner as it worries me that it says about only being used by professionals on the bottle ?
And lastly can someone tell me the uses for APC and what dilution rates should be used for them ?
I would really appreciate the help and advice and would like to thanks you in advance.
Regards
Mark
LNB is a liquid wax that one can apply by hand or machine. No cleaning or polishing power. The car needs to be clean before applying.
QW+ is a spray wax used to touch up a wax job after washing a car. It can be used on finger prints as a quick touch up at a car show. (I prefer using QD+ or S&W for this, though.) It won't last as long as LNB.
Difference between LNB and Natty's paste is mostly through application. Some people prefer using a machine to apply wax and LNB might be easier for them. There is also a different look between them.
I haven't used S&R, but from what I've read, it's for pros because it's potent and works well enough for the professional high volume shop, rather than a mild fool-proof formula that's just for light cleaning.
APC can be used for many cleaning tasks, from glass cleaning (somewhere around 1:128 dilution) to tough degreasing at full strength. The proper dilution will depend on the task at hand. Many people like ratios between 1:3 and 1:10.
BJohnson
As long as the wheel is clear coated S&R will work fine. I always just give the wheel a really good rinse and then spray over entire wheel including the inside. If the inner part of the rim isn't corroded it should break up the grime. I still like to agitate if I can get in there.
As far as QW+... I really like this product. Not so much to replace Natty's but like Leegr said, just to touch up after you wash. Just make sure the car is entirely dry, mirrors, door handles, around windows any little place that can hold some water. If you don't have a Metro Air Blaster then a leaf blower will suffice. Once you have your car clayed, polished and waxed the best thing to do is wash with SS&W along with the QW+. Your ride will look outstanding! :smt023
