Interior and Exterior Trim product questions
buja
Hi all, this is new territory for me...please correct me if i'm wrong .
Exterior trim such as the rubber strips on the roof , exterior bumper plastics, side mirror plastics, windscreen wipers and the plastic bit holding them.
Product to be used should be Trim Restorer right ?
How is the application like ? Apply with yellow foam applicator then leave for 30 mins then buff off with mf right ? hows the durability like ? and i assume this restores the light grey to the original dark black colour and also leave behind uv protection ?
Interior Trim such as dashboards, steering wheel, interior door panel trim, door rubber seals(???) . Natural Look ? what kind of finishing does it leave behind ? non greasy and matt finish I hope ? I've only ever used 1z cockpit premium. again whats the application procedure like ?
Natural Look can be used for my tires too right ? It will be good if I can avoid the need of buying too many products. instead of getting an additional bold and bright for the tires...
Thanks !
Natural Look can be used on tires, but won't last too long. It's intended for interiors. As mentioned in your other post, it will be more shiny if you apply it and leave it, less shiny if you buff afterwards.
Trim Restorer is for exterior trim. Sometimes it takes multiple applications to restore trim.
