Can I use all these products on one detail?
Snowdrift
I just purchased the following products and would like to use them all when I detail my 4Runner. Can I use them all on the same go around? In what order would I use them? Thank you! Professional Polish, Black hole, EX, EX-P, Natty's Red.
You *could* use them all, but it would not be needed. Usually either EX or EX-P are used, not both at the same time.
Also, to get the longest durability from the sealants, you should leave it to "cure" for a day before topping it. If you just like the look of adding a sealant under the wax, and plan on re-waxing monthly, then there may not be an issue if you apply product over the sealant right away.
Pro Polish
Black Hole
EX or EX-P ( you should wait 24-72 hours before topping) but if you are going for looks vs durability, then go ahead and top it with the Natty's Red
