Results 1 to 19 of 19
Thread: Foam cannon ?
  1. #1
    Foam cannon ?
    I'm looking for a foam cannon and don't know which one to get. The pressure washer is gas and 2250 psi (roughly). I'm open on any suggestion on which one to get one to get.
  2. #2
    Administrator Poorboy's Avatar
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    Quote Originally Posted by chupacabra View Post
    you might try one of our distributors and make sure you get the correct attachment .. we use one from Autogeek
    life is short ...do it while you can
    www.poorboysworld.com = store
    561-409-3710
  3. #3
    Advanced Helper ShinyRex's Avatar
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    I bought a cheap one off of the net for under 20.00, mainly because I wasn't sure if I would like the whole foam thing or not. It i made out of heavy brass fittings and it is fully adjustable so I am not sure what the nice ones get you besides multiple attachments. I am using mine with a 3000 psi gas pressure washer, and so far, so good. I think if you only need the 1/4 quick disconnect then you have lots of option but if you need a proprietary connection then it seems like you might have to go with a more expensive model.
  4. #4
    Quote Originally Posted by Poorboy View Post
    I went to Detailed Image site they have two foam cannon both look alike and have the same specs, psi rating, and so on. Then their the one that look likes the MTM PF22. I want to get the one that can produce the most foam without throwing the soap into the equation yet.
    The pressure washer gun and wand is not the one that comes with the pressure washer but bought separate. I got it at the Home Depot its the Power Care gun and wand. The wand has a 1/4 quick release for the tips.
  5. #5
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    Quote Originally Posted by ShinyRex View Post
    sounds like the online deal is a good option as long as you know what parts you are needing in advance .. I don't think there is a lot of difference in them as long as they have quality brass components
    561-409-3710
  6. #6
    Might sound like a dumb question but how can you tell if it has quality brass components? Should I look for one with the highest psi rating because it might be built better?
  7. #7
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    PSI should at least match your machine .. not really sure how to judge them
    561-409-3710
  8. #8
    Thanks for the replies! I'll take a look at the Autogeek cannon.
  9. #9
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    I went by reviews, if a product can maintain 4+ stars after several thousand reviews then i don't worry about it too much. So far it has worked for everything from a 20.00 hand coffee grinder to a foam cannon. I have never gotten to play with one of the nice foam cannons but mine has heavy brass fittings and seems to be made well, only time will tell if it holds up for the long run.
  10. #10
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    that's great .. do you have a link from where you got it?
    561-409-3710
  11. #11
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    So it appears several thousand was for the grinder. But the foam cannon still has over 1 thousand reviews, we'll worth the risk for under 20.00.
    https://www.amazon.com/DUSICHIN-SFL-.../dp/B00WPKHFA6
  12. #12
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    looks like a great deal
    561-409-3710
  13. #13
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    and I got a bottle of your new soap in the mail today so this weekend I get to play
  14. #14
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    enjoy
    561-409-3710
  15. #15
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    Poorboys new soap (after a few seconds of dwell time) via my cheap foam cannon
  16. #16
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,765
    Rep Power
    50
    nice coating of foam
    561-409-3710
  17. #17
    Helper rlmccarty2000's Avatar
    Join Date
    Jun 2016
    Location
    Fitzgerald, GA
    Posts
    3
    Rep Power
    0
    I've never been able to figure out what make a foam gun a $20 model vs a $100 model. I never hear about them exploding or anything like that.
    The Devil is in the Details.
  18. #18
    Join Date
    Feb 2011
    Location
    Virginia
    Posts
    244
    Rep Power
    12
    I think one of the more expensive ones comes with several adapters, but if your PW has a standard 1/4 inch adapter then you have more options. Maybe they have a little better fit and finish but for occasional use it is hard to beat 20.00.
  19. #19
    Take Pride in your Ride! Merlin's Avatar
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    180
    Rep Power
    11
    Quote Originally Posted by rlmccarty2000 View Post
    I believe it comes down to the design of the spray head.
    Some make better foam with lower PSI pressure washer.
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
