Results 1 to 17 of 17
Thread: Spray and Rinse ?
  1. #1
    Spray and Rinse ?
    Can Spray & Rinse be used on basement cement floors? I've tried APC, citrus degreaser, bleach and nothing remove the stains and since alot of cement floor cleaner are acid based I thought about Spray & Rinse.
  2. #2
    Administrator Poorboy's Avatar
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,779
    Rep Power
    50
    You can try but the ingredients in Spray & Rinse might not affect certain stains ... was it Poorboy's APC? another little known Poorboy's World product is Driveway cleaner ... it's all Natural and nothing cleans concrete, pavers, or blacktop better. You might need to call to get some...
    life is short ...do it while you can
    www.poorboysworld.com = store
    561-409-3710
  3. #3
    The APC that I use are the Meguiars, Super Clean, Zep Citrus Degreaser, and Purple Power and using a pressure washer. I forgot all about the Poorboys Driveway Cleaner, I'm going have to give the Driveway Cleaner a shot. Thanks for the reply!
  4. #4
    Token Brute BigLeegr's Avatar
    Join Date
    Apr 2006
    Location
    Canada, Eh?
    Posts
    1,530
    Rep Power
    50
    If the concrete hasn't been sealed, it may be that the stains have soaked into the concrete (it's porous). If that's the case you may need repeated applications over a long period of time to "lift" the stain out. Something I've heard about but not personally used is placing kitty litter on the stain to absorb it out of the concrete. (The fresher the stain the better this would work, of course.)
    If the concrete has been sealed, you may be able to remove the sealer (and with it the stain) then re-seal.
    Wanna get banned? Axe me how!
  5. #5
    Join Date
    May 2014
    Posts
    173
    Rep Power
    7
    Kitty litter will work. It depends on the stain
  6. #6
    The stains were there for over ten years and when in the basement they are just an eye soar looking at them (quarter of the basement). I was doing an oil change on my pushing lawn mower and spill some where the stain are and threw kitty litter down, it absorbs the oil but the stains are still there. Someone told me to try lemon juice or vinegar because it acidic not sure if it works though.
  7. #7
    Thanks for the replies everyone, much appreciated
  8. #8
    Join Date
    May 2014
    Posts
    173
    Rep Power
    7
    Try the litter again. Just take a block of wood and grind over it. Worth a shot.
  9. #9
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,779
    Rep Power
    50
    if the Driveway cleaner can't do it, it can't be done ... it really is that good especially if you use hot water with it , as it says on the label
    561-409-3710
  10. #10
    Quote Originally Posted by jtford95 View Post
    So pretty much you are using the litter as it was sand paper and rubbing it in. Before I just let it sit there for a few day and let the litter soak up the spill and then push it around with a broom and scoop it up. I'll give it a try.
  11. #11
    Quote Originally Posted by Poorboy View Post
    Is it only available at Poorboys World? I tried looking for it online and can't find it nowhere.
  12. #12
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,779
    Rep Power
    50
    I know we have it and possibly Detailed Image
    561-409-3710
  13. #13
    I couldn't find it on Poorboys World website, Detailed Image doesn't have it on there site and a Google search couldn't find it. Do you have to call Poorboys World for it? The driveway cleaner kind of remind me of the stuff I use to clean my friend work garage floors with. It goes on orange/yellowish and turns green when in contact with water, If it is simular stuff it's a excellent cleaner with very little agitation.
  14. #14
    Join Date
    Mar 2006
    Location
    New York
    Posts
    3,779
    Rep Power
    50
    yes, you may need to call or email dwayne@pooroysworld.com .. and yes it does work like that and we have cleaned some incredibly bad work floors including our last warehouse in NY that was a taxi dismantling garage .. grease was about 2 inches thick !! It comes in 8oz jar or gallon container ..
    561-409-3710
  15. #15
    Thanks for the reply! I'll call Dwayne to order some.
  16. #16
    Join Date
    Jul 2014
    Location
    North Carolina
    Posts
    81
    Rep Power
    5
    This is where I picked up 2 containers. (DI)
    Still haven't used it, however that will change as I recently made a mess in the garage
  17. #17
    Advanced Helper Scott P's Avatar
    Join Date
    Apr 2006
    Location
    Houston, TX
    Posts
    138
    Rep Power
    14
    I've given driveway clear a shot in my garage and it worked well. I need to try it again one of these days.
    Nothing in life is to be feared. It is only to be understood. - Marie Curie
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
