Product order and use, help...
F
Flash69
Ok so I have almost all of PBs products. I have been spending time learning how to use them, however now I have the new PB stuff and I am not sure where to use them.
Here is what I did on my Black 99 Cobra today. I have a PC 7424.
SSR 2.5 - Lake Orange pad - spread on 3 - breakdown on 6
SSR 1 - Lake White pad - spread on 3 - breakdown on 6
Pro Polish - Lake White pad - spread on 3 - breakdown on 5
Black Hole - Lake Black pad - spread on 3 - breakdown on 5
PwC (Blue) - Lake Blue pad - spread on 3 - breakdown on 5
EX-P - hand
After 15 hours I will apply another coat of EX-P. Then after another 15 hours I am going to apply Natty's Red.
Am I using the products correctly and in the correct order?
The problem is I have really let my paint get bad on this car. I know I should be shot! I had to use this car for a daily driver for a long time and it has major rock chips and etched clear coat.
Also I would like to know what products can be used to remove 2000 grit wet sanding marks as I feel some of the problems will be removed with wet sanding.
I'd use the Black Hole after PwC, myself. PwC has some polishing/cleaning abilities, so you'd be removing some/all the BH.
