Morfious
First off I have recently switched to Poorboys Products and I love them. I am fairly new to detailing with a PC buffer. I have done a few cars so far (with a friends help [Go-N-Def on these forums] on the first ones). So I had first hand knowledge on how to use the tools properly from the start.
The next two cars I have done were a 1997 Jeep Wrangler and a 1994 Toyota celica with some neglected paint. Swirls and oxidation etc. On both I have used the following:
SSR 2.5 with an orange CCS pad then
Pro polish on a CCS White pad
Final layer of sealant over the whole thing with CCS Black pad.
I have had a few problems with the Pro polish. Most of the panel comes out fine, but there are a few areas where the polish seems to be caked on and will not come off regardless how hard I push with the buffer, in fact pushing very hard will make the problem worse. The residue will come off by hand, but I thne have to "polish" out the troublesome areas by hand, which is annoying.
For both the SSR and the Pro polish I spread it on 1-2 and use 5-6 to work it in. I work it in for at least 5 minutes and have seen the videos describing the polish breakdown, so I feel that I'm working the product in long enough (maybe overworking it?). I am wondering if there is contamination on the pads or if there is some problems with my technique.
As for product amount I either use an X pattern or 1 full circle around the outer edge of the pad. I also get some dusting after a while, but I can deal with that.
Any suggestions or recommendations would be greatly appreciated.
