Polishes working/breakdown
ShawnF350
I found a post to the use of SSRs.
Basically continue polishing until you see the polish almost gone and shine coming through?
It's been months since I touched my polishers.
Do you do the same with PP AND PP2?
What about Master Cut? *Only going to use on a super swirled older car to test.
I have them all just want to be sure I'm properly working the product.
Yes they all basically break down and you work until there is a light film with shine popping through. You do sometimes have to stop and wipe off a section to see where you are really at in the process. The SSR's will tend to dust a little when they are done, whereas the PP2 will work until you decide to stop. The Master Cut, which is a HD Compound ... can finish out really well, but i would suggest either Professional Polish or SSR1 or 2 for final polishing.
Also remember not to use too much product as it will induce sling ;)
