PC ....
K
Krisekca
Hmm i have question ... could i f.. up anything ?
what i did
i applied Diamond White glaze by hand with yellow foam pad. after it was hazed i decided i will buff it with PC and Blue PAD i shouldn't do that right
I wouldn't have done it that way. What does the paint look like? A blue pad isn't very aggressive, so if you did mark up the paint, it shouldn't be too hard to correct.
Beercan31
depending on your skill with the PC, at worst you might have given your self micro scratches. i have done the same thing and all i did was clog up a good pad with excess used product, you should be fine, remember glazes have great hiding abilities so you will not see your mistake for some time.
