Natural look application ?
Can i use Natural Look on the steering wheel (I believe it's leather not sure if it fake leather) or does it leave a slippery film behind?
yes, and it will clean as well as protect ... you should buff well with a cotton cloth , not microfiber, and it will not be slippery, just clean :)
Can you spray the microfiber to apply Natural Look then buff off with cotton? Thanks for the reply!
the problem with using microfiber is that it is so absorbent that it is picking up what it is supposed to be spreading ... use cotton with all dressings ... you can apply with foam
Yes you can spray the cloth instead of the surface. In fact, that is a good practice. By doing this, you limit the amount of over spray that may get on the instrument cluster or windows. To be even more careful that way, you can put a flip top lid to pour the product out of the bottle instead of spraying it.
