My new detailing vehicles. Focus and Mustang.
W
wallywax
At the end of last summer I sold my S-10. So now my little Focus and Mustang are the vehicles that I am using for my business . I just made up two signs that are almost identical to my business cards for the Focus and the mustang has RP detailing in the quarter windows. I do miss the truck. I mainly miss the 90 gallon water tank and pressure washer. Do you guys think any customers would get turned off due to not having my own water supply?
My old truck:
There seems to always be someone unhappy with some aspect of anything. You could get a trailer if needed. You could also carry around a 20 gal. tote with water in it and use a bucket to dip the water out as needed. You could use a pump up plant sprayer as well, if you felt it were necessary. I've even seen pressure washers that hold a reservoir of water and run off the 12 volt outlets in the car so you can still have some force behind it if needed. (Not sure how "commercial quality" they would be, though.)
W
wallywax
Good advice! I was actually thinking about purchasing one of those portable Nomad pressure washer with the 3 gallon tank built in. Not sure how good it works but I am thinking about it.
never had a problem of using a customer's utilities .. good luck with the new vehicle Walter
