just a little thanks
T
titan
I RECENTLY PURCHASED YOUR CAR WASH WITH SSR1,SSR2,BH,PWC,NATTYS BLUE,WPC, AND EX-P.I DETAILED TWO CARS IN THE PAST TWO DAYS-ONE WITH ADAMS POLISHES AND 1 WITH YOURS.I CLAYED THE CAR USED SSR2 THEN SSRI THEN EX-P TOPPED TODAY WITH NATTYS BLUE.I MUST SAY THAT IT WAS IMPRESSIVE-VERY IMPRESSIVE-THE POLISHES AND WAXES ARE EASIER TO USE THEN ANYTHING I USED BEFORE AND THE DEPTH AND SHINE ARE INCREDIBLE. VERY EASY TO USE WITH A PC.I GAVE THE OTHER STUFF TO A FRIEND.
T
titan
ALSO WANTED TO ASK-I USED A GREEN CCS PAD FOR THE SSR2 THEN A WITH CCS PAD FOR THE SSR1 THEN A BLUE PAD TO APPLY THE EX-P.EVERYTHING TURNED OUT SPOTLESS.I WAS WONDERING IF I NEED SSR3 IN THE FUTUER WHAT PAD WOULD I USE.
SSR 3 is very aggressive. Most people wouldn't need it. (Doesn't mean you can't get it "just in case" though. ;) )
welcome to our forum ... I personally have not had a lot of luck with the green pad ... it has always left marring behind ... I prefer the Orange (light cut) or white (polishing pad) ... SSR2.5 would be your next step up and that again I use with either the Orange or White pad .... if you should decide to get the SSR3, and you didn't say what kind of machine you are using, i would use a white polishing pad with a pc or rotary or for after wet sanding a wool pad and the rotary.
