There are two ways you can seal your finish- by hand or by machine. Certain products require hand usage only, yet most can be applied either way. Waxes and sealants are generally applied and removed the same way. Be sure to read the manufacturer’s directions on proper usage and dry time, as all products vary.
By Machine-
Use the softest foam pad possible. Apply the wax or sealant directly on the foam pad. Every product varies in amount needed and may require some tweaking as you go. You definitely don’t want the pad soaked in product, it’s just a waste. Keep the speeds very low, there is no need to use a fast speed. There also isn’t a need to work the product into the paint as you would a polish. Going over a panel two times would be sufficient to ensure even coverage. Using a machine may use more product but it’ll apply a very thin layer of wax or sealant. Remember, thin is in! Allow your LSP to fully cure/dry on the paint and then remove with your favorite microfiber towel.
By Hand-
You can’t get any closer to your vehicle than by waxing by hand. You should apply your sealant or wax with a foam, terry cloth, or microfiber applicator. Application techniques vary as well, but most say to apply your LSPs in the direction the wind flows over your car ie- no need for circles. It is debatable whether or not you can apply wax thinner by hand or machine. Once again, try to get your layer of protection as thin as you can. Once your product is dried and ready to be removed, grab a fresh microfiber towel and remove all excess residue.
Removal by machine-
Some people prefer to remove their LSPs by machine. Using a microfiber bonnet over a foam pad you can easily remove even the most stubborn wax. Once again, keep the speeds low and keep an eye on the bonnet to make sure it doesn’t get loaded with excess product. Switch to a fresh bonnet as needed.
By Machine-
By Hand-
Removal by machine-
