HD Fabric Protector
Description
This amazing, super hydrophobic product can be used on fabric, leather, suede, and many other materials. You can blot away any greasy or watery spills with an absorbent cloth or tissue. Water repllency can be restored to clothing as well. Can be used on any fabric surface and will not change the feel, look or breathability of the fabric.
Instructions
WARNING: Before using this product, MAKE SURE TO TEST FOR COLOR FASTNESS IN AN INCONSPICUOUS AREA. If color rubs off or changes, do not use.
DIRECTIONS:
Make sure material is clean and dry before using.
1. Adjust spray button to dot on rim.
2. Hold can upright and about 6 inches from fabric. Spray with a slow sweeping motion until evenly covered and overlap. Pleats and creases will not be affected.
3. Protect surrounding areas from over spray. If over spray occurs gently wipe off with a soft cloth.
4. Spray lightly when applying to nylon and other dark shiny synthetic fabrics.
5. After using product, allow material to dry for one hour.
6. Test for repellency: sprinkle a few drops of water on the treated material. If water soaks into substrate, repeat.
7. Reapply after cleaning or laundering.
Product Description
Cquartz Fabric & Leather Coat
Cquartz Fabric & Leather protection is nano-technology based and is an extremely durable Super HydroPhobic product for fabric and leather protecting against UV degradation, sweat, salt, water, liquids, dirt, bacteria, and stains. Fabric & Leather Coat does all this without affecting the breath-ability of the material. Traditional products make fabrics feel stiff and clog the weave of the fabric, preventing breath-ability. They are unable to stand up to tough cleaners and less resistant to wear. Using nanotechnology, our treatment is small enough to attach to individual fibers, delivering superior performance characteristics without compromising the look, feel, or comfort of the fabric and without clogging the fabric weave.
Cquartz Fabric & Leather transforms the substrate into a super hydrophobic surface that is both durable, flexible, and long lasting against harsh or caustic detergents.
Areas Of Application:
• Convertible Tops
• Fabric and leather seats
• Headliners
• Fabric Wheel wells
• Upholstery
• Carpets
• Floor Mats
• Sunshades
• And more...
Features:
• Super Hydrophobic: Liquids are repelled instantly
• Durability: Withstands mechanical wear for up to a year and withstands strong soaps and high pH intensive detergents
• UV protection: Protects against UV degeneration while maintaining the supple feel and original color of treated surfaces
• Breathability remains
• Versatility: Protect many surfaces such as fabric upholstery, leather, carpets, mats, & convertible fabric tops
• Suitable for textiles and finished leather
• Long lasting protection for textiles and leather against water, dirt and grease
• Appearance: Transparent
• Revives dull faded interiors and protects them from further attack
• Protects leather from surface wear, dirt, and stains.
• Resists bacteria growth from sweat, dirt, oils, and liquids
• Requires less cleaning: In most cases simply wipe with a damp microfiber towel
Coverage: (Estimates shown based on spray for fabric and spray/spread for leather)
• Apply using atomizer, sprayer, (or for leather wiping on is also an option that saves on product)
• 1.0ml per 1 sq. ft. for leather application
• 2.7ml per 1 sq. ft for fabric application
Directions for Fabric:
• Clean the surface completely from dirt, dust, and all oils and dressings, if cleaner has any by products then steam wipe with damp cloth to remove residue before allowing to dry completely.
• Shake CQ Fabric & Leather Coat well
• Spray onto surface evenly
• Park in the sun or use blow dryer to speed curing time.
• Must be fully dry and cured before subjecting to traffic or abrasion.
Directions for Finished Leather:
• Spray on leather and then spread with CarPro-US Microfiber suede towel (4" or 8") Don't try to spread too thin but simply spread evenly.
• Wait approximately one minute and lightly wipe with CarPro-US MicroFiber Suede cloth (8" or 16")
AfterCare:
• When dirty simply wipe suface with damp microfiber or use an interior cleaner if you prefer
• Avoid using shampoos containing wax or silicones or they will temporarily affect the super hydrophobic effect
Precautions:
• Test in inconspicuous area on any surface you are unsure of
• Use in ventilated area
• Avoid Skin and eye contact
• Keep Container closed after use
• Keep away from Children
The set up before test.
CarPro Fabric Protection
After water applied, as quick as I could dip fingers in bowl of water and then take picture.
HD Fabric Protection
This is my first application of HD Fabric protector and seems to work very well.
This is my review of both products; your mileage may very well vary. See and judge for yourself.
