Frozen and Thawed Bird Sh#t remover
jmoran_11
Hi,
I foolishly forgot about a bottle of Bird Sh#t remover I had in the car last winter. It must have frozen and thawed at least 5 times and is now watery and dark green. Am I right to assume that it will no longer be effective?
Thanks!
I can't say anything about BSR specifically, but my general rule of thumb is if a product mixes back together after shaking, I'll try it. I think it may still work if you shake it well before use, but maybe PB or Pockets will chime in.
jmoran_11
Thanks! That's the thing it does not seem to have separated, it is just very dark green and does not appear as slick. No matter how much I shake it, it does not go back to how it used to look unfortunately.
as a water based product it can freeze and defrost with little to no damage to the product ... it was never meant to be slick, just a BSR ...color doesn't matter either as the freezing can change the color and scent.
I know I am late to the party here, but I keep 16oz bottles of BSR and S&W in the truck for cleaning the windshield, and quite often they get frozen over the winter.
I have gone as far as to thaw in the truck to use them to clean the windshield right on the spot, and they seem to work just fine for me.
S&W turns very light green ( lighter than normal ) after a freeze / thaw.
ShawnF350
I had a bottle freeze over the winter too.
Seems to work as it did before freezing.
I did find that when any PB bottle was mostly full.. The bottom expanded enough to allow it to fall off the shelf and onto the floor.
I think that's the freeze indicator.
