4
4pbears
i am looking for a good product that can remove medium grade swirl marks, and was wondering if something like ssr 2.5 can be applied by hand?
Dave.
Dave.
I have also done this but wouldn't recommend it.Poorboy said:I also usually recommend only SSR2 by hand , but i have used both SSR2.5 and SSR3 by hand, it's just a lot of work and you have to do very small sections at a time :wink:
That or lack of machine.littlemissGTO said:I would think that the biggest reason to use any of the SSRs by hand would be for scratches near doorhandles or am I mistaken?
BigLeegr said:That or lack of machine.littlemissGTO said:I would think that the biggest reason to use any of the SSRs by hand would be for scratches near doorhandles or am I mistaken?
Maico said:Does it just take more elbow grease to rub in the SSR2.5 and SSR3 by hand, or why is it that you guys only recommend using SSR2 and below by hand? I don't have a PC yet, but I'm still saving up for one, but I figure I could try polishing by hand and seeing how that works.
Poorboy said:Maico said:Does it just take more elbow grease to rub in the SSR2.5 and SSR3 by hand, or why is it that you guys only recommend using SSR2 and below by hand? I don't have a PC yet, but I'm still saving up for one, but I figure I could try polishing by hand and seeing how that works.
yes it is possible by hand but you should do small areas at a time and expect to work pretty hard :wink:
Check this page out. It helped me quite a bit. Lots of great information is featured there.schrader said:ive never used a polish before, how do you tell when its broken down when doing it by hand? and how do you know how much to use?
bakchoi said:results look pretty good by using just hand. is it best with a micro fibre applicator pad or a blue or yellow foam pad?
thanks
