F
FreeBIZZ
Hi All,
I plan to detail a new VW GTI this weekend. Since it is brand new, it does not have any major defects in the paint. I do see some very light swirls in certain lighting conditions, though.
My plan is as follows and I need some suggestions about applying and removing these products. I have a PC.
WASH
CLAY
PWC Blue
1-What LC pad----I am thinking a white polishing pad
2-Will this hide or take out the lite swirls, or should I use SSR1 first, and if I use SSR1, will this white pad be good enough?
3-How long to leave PWC on, and how well does it come off with a MF or Terry bonnet, or do you use MF by hand?
EX-P
1-What pad-I'm thinking a white polishing pad, but I could go to a black finishing>??
2-Any tips on applying?--
3-How long do you leave on and do you do the entire car at one time?
4-Removal----do you use a PC, and if so, is a MF or Terry bonnet the best? How easy is it to remove?
5-Any other tips?
Next steps:
1-I read somewhere in doing a search here that itr might be good to apply a couple layers of EX-P, then go to a single of EX to add some carnauba, then finally top with Natty's Bl. What do you think?
2-Should I just skip the EX-P and go right to EX? Is EX easy on/off and the same apply/remove method as EX-P?
WASH
CLAY
PWC Blue
EX-P
5-Any other tips?
Next steps:
